Horloge LED
Produits, nouveautés
Horloge LED
Messagepar Stainless » Lun 26 Aoû 2013 à 17:12
Proposée par le club anglais, une horloge LED de remplacement intéressante, en vert ou bleu :
Below are a few images of the unit I managed to take this weekend. The one in the actual dash is the blue version I created, but I'll take a few pics of the green version in the next couple of days in VIN 10719, just to give you an idea.
All parts are laser cut to size, and the lens is a perfect fit. Connection to the car is simply via a live and ground 12V wire, which can be done to the original clock wiring, or as I have done to a permanent 12V feed (similar to the amp). The unit simply bolts onto the original clock fitting posts under the console plate with two washers and two nuts and is very secure.
In effect the units are "version 1.6" (a few alterations after testing so far) so I've not tested them long-term, but the electronics are good, and held secure in the frame. Any suggestions or criticisms are welcome.
If people are interested I'm looking to sell the first four units at £55, which includes postage and packaging. This is MUCH lower than any other replacement clock out there.
If you're interested then PM me through here, or email me a
t mark@flux3d.co.uk
:arrow: http://www.deloreaneurotec.co.uk/forum/ ... =35&t=3772
Messagepar Alex » Lun 26 Aoû 2013 à 20:54
Genial c'est tout ce qui me manque ! j'ai envoyé un mail, par contre j'hésite entre bleu et vert, c'est quelle couleur d'origine déjà ?
Messagepar warduke » Lun 26 Aoû 2013 à 21:14
warduke
Messagepar doc.63 » Lun 26 Aoû 2013 à 21:14
A l'époque quand les afficheurs led n'étaient pas rouges ils étaient verts :wink:
Messagepar Bastien-fma » Lun 26 Aoû 2013 à 21:43
Sa a l'air d'éclairer vachement leur horloge ! Mais la mienne étant à l arret depuis presque un an, je vais certainement investir. Dommage que ce n est pas le même design que l originale.
Vous croyez qu on peut avoir un prix si on commande a plusieurs ?
Messagepar Stainless » Lun 26 Aoû 2013 à 22:17
Bastien-fma a écrit: Dommage que ce n est pas le même design que l originale.
l'originale n'est pas à LED mais à tube plasma, difficile à refaire
Messagepar aventure » Lun 26 Aoû 2013 à 22:21
The dream come true
Commande faite pour une version verte :D 8)
Messagepar Alex » Lun 26 Aoû 2013 à 23:06
tu as pris l'ancienne ou la nouvelle version ? J'ai pas compris la différence. Je pense prendre une bleue, je trouve que le vert agresse la rétine.
Messagepar aventure » Lun 26 Aoû 2013 à 23:18
OEM version et en vert, je vais pas faire du tuning dans 614 :lol:
C'est pas donner, mais le contact avec le vendeur est super direct :wink:
je crois comprendre que l'OEM a un affichage plus d'origine.
Messagepar Bastien-fma » Mar 27 Aoû 2013 à 22:17
qu'appelles tu " pas donné " pour l'OEM version verte ? 55£ ?
Pour ceux qui voudraient rester dans le format 99 % d'origine, j'ai retrouvé ce lien !
http://delorean2109.blogspot.fr/2008/03 ... pdate.html
ainsi que le lien du vendeur
http://www.dakotadigital.com/index.cfm/ ... ry_id=261/
ca nécessite certainement de reprendre le corp de sa vieille horloge mais sa doit en valoir le coup aussi ! qu'en dites vous ??
Messagepar aventure » Mar 27 Aoû 2013 à 22:54
OEM, c'est comme l'original, mais dans ma boite au lettre c'est £72 au final.
Si tu regardeS bien les deux photos, la verte est de format original, la bleu est plus grosse, donc pas trop d'origine :wink:
Messagepar Alex » Sam 07 Sep 2013 à 19:55
j'ai installé cette merveille, c'est vraiment bien foutu, un peu cher mais le prix est justifié. Pour une fois :lol:
l'installation est très simple, c'est du plug and play. Connectez le noir à la masse et le positif soit sur le rouge du fil d'origine de l'ancienne horloge qui va au violet pour avoir l'horloge allumée en permanence, soit sur le vert qui va au blanc vert de la voiture pour allumé l'horloge uniquement en mettant le contact.
Merci à Mark Sutton pour ce bel objet :D
Messagepar aventure » Lun 23 Sep 2013 à 15:08
Et si la montre que vous avez au poignet vous suffit, voilà le plan B :D
http://www.awildermode.com/2013/09/custom-delorean-clock-plate.html
Messagepar Le Montagnard » Mar 24 Sep 2013 à 10:09
C'est une solution aussi...
Messagepar jojo » Mar 24 Sep 2013 à 18:06
Je préfère le bidul de richesse de Raphaël
ou mieux la centrale de Ylrik
Retourner vers Shopping
