Anthony / VIN 4528
Messagepar Anthony » Ven 30 Déc 2011 à 19:56
je ne sais pas encore exactement, mais normalement mi-Janvier
Messagepar cooldrick » Lun 02 Jan 2012 à 16:46
tu l'as faite réhausser de l'avant ou pas?
en tout cas une belle cure de jouvence. faut savoir passer la main pour reprendre le plaisir ensuite 8)
Messagepar Anthony » Lun 02 Jan 2012 à 18:04
Oui rehausser de l'avant :wink:
Messagepar arcadion » Lun 02 Jan 2012 à 20:22
Tu la trouvais trop basse ? Ou ca touchait avec les anciens ressorts courts ? Quels ressorts tu as / tu avais ?
Messagepar cooldrick » Mar 03 Jan 2012 à 18:54
l'arrière était aussi rabaissé ? tu l'aas laissé tel quelle ou pas?
je te pose beaucoup de question :mrgreen: car j'envisage de relevé l'avant de la mienne également
Messagepar cineman » Mar 03 Jan 2012 à 20:41
Anthony has Spax shocks front and rear, DMC-EU front lowered springs and stock rear springs. Rear shocks has height adjustable, so stock springs can stay.
The front of the car was a bit too low for Anthony, it was about 2cm lower than usual for DMC-EU springs.
The cause was a combination of things, so i prefered to change all was possible: new upper rubber springs support ( old was bit crushed, so gain few 'mm ) .
I changed the lowerball joint also: the one from SpeciaTauto are good and not break, but they have a little different cone, wich is 3-4mm higher, so in doubt I changed with the new UK one's wich are made exactly like original.
And just to be sure the problem was not a manufacturer problem with the springs, i changed them with new one. Once out, the old springs was some mm lower than the new one, maybe was just setted after use, but now we see the car at good height, and we'll see if change again ;)
cineman
Messagepar ohms » Mar 03 Jan 2012 à 23:05
Good Job Andrea, I have the same Problem with 862, juste for information, can you tell me the higher of front springs you want to put on Anthony's car ?, actualy I have 32cm front spring.
Messagepar cineman » Mar 03 Jan 2012 à 23:12
ohms a écrit:Good Job Andrea, I have the same Problem with 862, juste for information, can you tell me the higher of front springs you want to put on Anthony's car ?, actualy I have 32cm front spring.
front springs i changed still with a new pair from DMC-EU: they are the same as before, i think just a little tolerance problem was in the end, combined with the other things. on all the other cars i had no problems.
cineman
Messagepar quentin88 » Mer 04 Jan 2012 à 08:36
après avoir rabaissé ma premiere delorean , je ne ferai plus cette erreur sur la deuxieme , le chassis frottait dans les chemins , il ramassait tous les cailloux , je la trouvait moins belle qu'avant et beaucoup moins pratique à utiliser ... :(
quentin88
Messagepar philippe19671 » Mer 04 Jan 2012 à 08:41
quentin88 a écrit:après avoir rabaissé ma premiere delorean , je ne ferai plus cette erreur sur la deuxieme , le chassis frottait dans les chemins , il ramassait tous les cailloux , je la trouvait moins belle qu'avant et beaucoup moins pratique à utiliser ... :(
he bien moi je suis sur le point de rabaisser l'avant de la mienne pour augmenter le poid sur la direction et diminuer sa sensibilité au vent laterale (que je trouve tres forte pour ce type de vehicule)
philippe19671
Messagepar arcadion » Mer 04 Jan 2012 à 09:46
cineman a écrit: a little tolerance problem
+1 !
J'ai remarqué des dispersions de production également... le respect des tolérances n'est pas bon : j'ai un écart droite gauche visible sur ma voiture (ressorts courts de DMC-EU également).
Renaud, suite à ton problème avec ces mêmes ressorts, tu as fait faire des ressorts chez "La Boudinette" je crois ?
Ca pourrait être une bonne piste pour les suivants ;)
Messagepar jjf » Mer 04 Jan 2012 à 20:05
pour tout ce qui concerne les suspensions, reconditionnement d'amortisseurs, ressorts,une bonne adresse à Orchies dans le nord, entre Lille et Valenciennes, ils font surtout dans la compétition mais sont capables de tout faire
http://www.performancesuspension.fr/
jjf
Messagepar Anthony » Mer 01 Fév 2012 à 13:36
Messagepar jojo » Mer 01 Fév 2012 à 13:58
very good
Messagepar Peabody » Mer 01 Fév 2012 à 14:41
T'es vraiment balaise !
Peabody
