"I dont know about crack on motor. Only way to see waterjacket is to pull heads off. Major work. Id sooner upgrade engine to 3.0 eagle with turbo.
A/c doesnt work but there is no belt. If its old r12 it needs to be updated.
There is no cooling problem.
I already had to pull off intake when I replaced water pump. All hoses gaskets and clamps were replaced. No leaks. I have car drivable for you, Body is excellent shape no rust...indestructible.
Previous owners were very neglectful. I did a lot of work to make drivable including clutch master Cylinder.I also hooked up emergency brake which was disconnected.It now works as designed. "
En gros à propos des soucis de la seconde proprio.
Domi > Je trouve ça pas mal oui
