Andrea - VIN 1748 (italy)
Messagepar Ace » Ven 10 Juin 2011 à 09:23
Fastest PRV powered Delorean ever? :wink:
Messagepar LED 76 » Ven 10 Juin 2011 à 17:28
good job , my friend . gratulation!!!!! :D
LED 76
Messagepar Florent » Ven 10 Juin 2011 à 18:05
Congratulation, it reminds me when a friend did a base map for my High Compression Honda :D
Messagepar cineman » Mer 20 Juin 2012 à 07:59
Hello dear friends :)
I see a lot of works here lately ;)
Here in Italy always busied :) also with deloreans...
I did pushed for founding limits on PRV... got a blown headgasket with turbo pressure :S but comparison showed that this replacement headgasket, taken from a serious Alpine part dealer, has this delicate point of failure, aside the cylinder, while the original one has just a smaller hole on the side, so not possible to "break" this way. So... original parts are lot of times better ;) go for it.
I then did a little of head cleaning and polishing, and the engine is already together and running.
I'm now working with the Megasquirt EFI i did put, and it works good, I just bought a wideband lambda sensor, so i can make a very precise map, but lately it was going quite good, and got around 11 km/lt on the highway.
Apart my car, i am putting together another special delorean for a friend, Giovanni, which was with me in Swiss. This is the engine we took there.
It got special forged pistons i let made on my drawings here in italy for more compression, got regrinded cams from a specialist in germany, and some other works. I hope to pass 200hp easily :) and now is ready, time to put all together in the car...
Other special feature are vented brakes front and REAR
and I'm working on something for the front suspensions...
( the steering wheel tierod is just a quick try...)
I got lasercutted a special tank plate, lot more heavy and to be reinforced, for a good triangulating little arm in line with the lower arm fulcrum.
cineman
Messagepar LED 76 » Mer 20 Juin 2012 à 18:38
j'ai pas tout compris mais c'est un sacre travail :D ci j'ai bien lu sa delo aura 200 cheveaux ?
good work and congratulations my friend
LED 76
Utilisateurs parcourant ce forum: Aucun utilisateur enregistré et 67 invités
