Page 1 sur 2
Sidemarker Front with Indicator/Turn Signal Function
MessagePosté: Dim 13 Mar 2016 à 19:52
par Sebastian_6577
Hello!
I combined the Function of the Indicators and the yellow Sidemarkers.
When you turn the Signal , the yellow Sidemarker will flash .
If the Indicator isn´t in function, the yellow Sidemarker will get in the "classic" Function back after 2 seconds.
I designed a Set of Modules which can be installed behind the Grille / DMC Emblem .
The Set is equipped with the original 3Pin Male / Female Connectors so you connect it between the Main Harness and
the Connector for the "Front Turn Assy"
Second Step is to connect the yellow Wires to the existing Front Sidemarkers and connect it.
With this small Fix ( 1h of work ) your yellow Sidemarkers will flash when you turn the Signal during the Lights are on
If you want to get the function every time ( even the Lights are off ) you had to connect the White Cables to the inner Space of the D and connect it
to an existing "Ignition" powered cable.
You can see the Function by using the Link
https://www.dropbox.com/sh/zqmfmhjnilwg ... Cv9Xa?dl=0
The Video Shows the Function ( starting 00:21 with the original US Style )
Please feel free to get in contact with me for more informations and Pictures.
The complete Set cost 92 USD ( 85 Euro ) without shipping.
If you will visit the Eurofest you can pick your ordered set there , so you won´t have shipping costs.
Sebastian
Re: Sidemarker Front with Indicator/Turn Signal Function
MessagePosté: Lun 14 Mar 2016 à 17:49
par Joedjd
good !is it difficult to instal it ?
MessagePosté: Lun 14 Mar 2016 à 18:48
par Alex
I like it ! 8)
MessagePosté: Lun 14 Mar 2016 à 20:03
par cooldrick
Alex a écrit:I like it ! 8)
Me too 8)
MessagePosté: Lun 14 Mar 2016 à 20:16
par Sebastian_6577
Almost Plug and Play. For step 1 and 2 ( 4 ) you will Need less than 1 hour with experience in soldering .
1.st Step:
The Box with the male and female connectors easy plug in between the main harness and the Front Turn Assy
( 100784 FRT TURN/SlDE LP ASSY Part 17 http://www.delorean.eu/catalog/index.php?cPath=19_26_60 )
The Connectors are 1:1 like the original 3Pin.
2nd Step:
Remove the H4 Lamps and install the yellow Wires to the Sidemarkers.
Cut off the Red Wire and sold the yellow wire . ( See the attached Images )
Install the H4 Lamps.
-> Now the yellow Siedemarkers will Flash when the Headlights are ON.
3rd Step ( Optional )
Every Box get a White Cable.
Install the White Cable on "Ignition" ( " 15" ) and the Sidemarkers will Flash when the HEadlights are on OR OFF.
It is an Option, so the Function is always active
In Moment i´m planning to make a 4th Step:
The Boxes will get a second function: Install a Mass Cable ( Black , 0V ) from the Boxes and you can Switch the Mass Cable on Ground
of the Car ( using a simple Switch ) and you can decide if the First Position of the Light Switch ( "Standlicht" in German, "Sidelights in English ? )
will be in the "US Style" ( FRT TURN/SlDE LP ASSY is yellow lightning ) OR the small Bulb in the H4 Lights are on.
I can send a pdf with a small install guide . Please send a PN with your email if you re interested.
Kind Regards Sebastian
MessagePosté: Lun 14 Mar 2016 à 21:40
par Alex
Me too 8)
Lol :lol:
Si quelqu'un va a l'eurofest pourrait il m'en ramener un je paie d'avance merci :wink:
MessagePosté: Lun 04 Avr 2016 à 18:30
par Sebastian_6577
MessagePosté: Lun 04 Avr 2016 à 18:46
par Alex
Nice, That will be available for the rear too ?
MessagePosté: Lun 04 Avr 2016 à 18:52
par liquidsnake
ça doit être bien pratique ça dans la circulation parisienne !!
MessagePosté: Mar 05 Avr 2016 à 09:46
par Sebastian_6577
No, only for the yellow Sidemarkers.
MessagePosté: Mer 06 Avr 2016 à 08:29
par Tom
Alex, just change your red rear sidemarkers for yellow ones and it will sure run well :lol:
Sebastan : nice produce, and realy well built !
MessagePosté: Mer 06 Avr 2016 à 16:40
par Alex
Scuse mi I donte anderstande wate you cede ! :lol:
MessagePosté: Mer 06 Avr 2016 à 20:08
par Sebastian_6577
Thanks for the comment :-)
Next Stage " Version 3.0" installed in 6577 today.
Same function like the first Release ( Version 2.0 ) , additional now there is the possibility to switch
between US Style and European-Style ( Sidemarker in H4 Hella Lights )
Pics will follow next days.
MessagePosté: Ven 08 Avr 2016 à 19:09
par Sebastian_6577
MessagePosté: Ven 08 Avr 2016 à 19:23
par Alex
nice box :D
